Reshape control geometry - convert rectangle object
encore
For whatever reason VW will not allow the reshape tool to modify a rectangle. You must Modify > Convert > Convert to Polygons, which then allows reshape to work.
I am trying to implement this in an object node as either a network or custom node, and cannot get it to work. Neither the 'Convert to Polygon' or 'Convert to Polyline' nodes make a rectangle reshape-able as control geometry, and neither 'vs.ConvertoToPolyline()' or 'vs.ConvertToPolygon()' seems to work in a script.
How can I automate the menu command 'Convert to Polygons' so that I can take a rectangle or other poly as a rehsape-able control geometry input?
Edited by encore
  • 3 months later...
  • Marionette Maven
Is there a reason you can't use a rectangular shaped poly as your control geometry object within the container? I'm able to use the reshape tool under that circumstance.
I do find it odd that a rectangle control geometry won't reshape, so I'll throw that in as a bug and see what comes of it.
