Kimcz Posted April 11, 2005 Share Posted April 11, 2005 I have always been able to change drawings simply from A1 to A3 by changing Print Size and scaling layers down by 50%. In 11.5, Drawing Labels and Callout Tools dont scale! Any suggestions of how to scale down to easily change all elements in the file without laboriously going through each drawing at A3, which takes forever. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 11, 2005 Vectorworks, Inc Employee Share Posted April 11, 2005 It is a bug that was unfortunately introduced in 11.5 that causes this; In the meantime, why don't you produce half-size drawings using scaling in the printer driver? Quote Link to comment
Kimcz Posted April 11, 2005 Author Share Posted April 11, 2005 Thank you Robert for responding so swiftly. Some printers of course can do that, some don't like it, or won't. Also you can't change the scale on the new scaled drwgs. Can you tell me when this bug will be resolved in the next update to 11.5? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 12, 2005 Vectorworks, Inc Employee Share Posted April 12, 2005 Fortunately or un-, I can't divulge release dates of future updates, that's against policy. What do you mean by "you can't change scale on the new scaled drwgs"? Quote Link to comment
Kimcz Posted April 12, 2005 Author Share Posted April 12, 2005 I mean that I can't type in the new scale in the titleblock, after having saved the file in a new name. With the print to 50% scale, the scale reads incorrecly, and with the print to fit, the drawing is probably not printed to accurate scale as well as not noted with the correct scale in the title block. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 12, 2005 Vectorworks, Inc Employee Share Posted April 12, 2005 Is the intent here to create half-size sheets for field review, or to reformat the entire drawing set? Because if the former, it might be better to add a "Printed at 50%" legend to your title block symbol and leave the scales alone... ? Quote Link to comment
islandmon Posted April 12, 2005 Share Posted April 12, 2005 To get around this issue my Title SCALE Block always includes the page size, ie SCALE : 1" = 10' @ 24x36. This avoids misunderstanding when the output is scaled at the PDF or Printer. Quote Link to comment
Kimcz Posted April 12, 2005 Author Share Posted April 12, 2005 Thanks for the above. It is however so much nicer to be able to label the drawing with the correct scale to avoid confusion. Clients and contractors understand it so much better. I do in actual fact have a scale statement on my standard titleblock, but nobody seems to read it, and in any case I have several scales on each file between different sheets. Quote Link to comment
