Janvin Lowe Posted December 26, 2021 Share Posted December 26, 2021 Hi all, so I was working on some construction details and I thought I'd use a couple of multiple view panes to reference some of the other sheets in my drawing file (I usually go back and forth with 2 in total but this time, 3 altogether); when I went to close one of the 3 panes, VW hiccuped and ended up placing a 'ghost' pane on top of all other panes when in Multiple View Panes (MVP) mode - this rogue pane as you can see in the screenshot below has a white strip (highlighted in the gray box below) that covers any other pane. The workaround, for now, is simply to use a floating pane which works without needing to be in MVP mode but it'd be nice to know how to 'purge' or close this rogue pane. Any suggestions on how to get rid of this 'rogue' pane would be greatly appreciated! Thanks! VW 2018 SP6 (Build 465771)(64-bit) Windows 10 Pro v2004 OS build: 19041.1348 Ryzen 9 5900X 3.7GHz 64 GB DDR4-3200 RAM NVIDIA GeForce GTX 970 Quote Link to comment
