I have been receiving the following message when I try to used the plant tool:
"The object you have selected is not a plant object. This may be caused because you have a non-Plant object in your Plant default content file(s)."
I able to select the plant tool, select the plant symbol I would like to use, and begin to layout the plants. When I try to complete the layout placement and end the tool's function, a window pops up with the above message.
How do I address this so that I can move forward using the plant tool for my landscape design? Pleas advise.
minimelis
Thank you kindly.
Cheers,
MC
1 answer to this question
