the frog Posted October 3, 2021 Share Posted October 3, 2021 Hello My goal is to count symbols or objects in a specific space and automatically show them in a label. I started remembering the webinar where you put points in a poly. First easy step, I want to make a network where a symbol is or not in a poly (easier I think than try with space) So, I draw an object and name it AA. I convert into a Symbol named AA-1 I draw a poly and name it. Built a network beginning by giving a name (bottom of the OIP) to a symbol and get the symbol location, get x,y convert into a point and use the intopoly node with the poly name. This works if I give a name to the symbol like BB-1 and I have the true or false value. This is of no help because if I have to rename each object it’s useless. So I tried to use the symbol name AA-1, but this returns nothing. If I use the object name it’s the same. I know there must be a way because you can count symbols in the sheets, but not in a specific space and show it in a label. Any idea? In the attached file the original webinar, the network that works with the object and a strange network (with the move node) that changes the place of the rectangle without changing its selection place. In this case I am using the name of the object in the symbol! into poly v2021.vwx Quote Link to comment
m.graf Posted October 3, 2021 Share Posted October 3, 2021 (edited) Hello, In normal worksheets (without Marionette) are functions and filters to get roomname or number of the placed symbols and also function and filters to get the Symbolname. For Marionette: into poly MG.vwx in this file i create you the Node "Get Symbol Name" and an example to filter "is in or on Poly"... If you want convert "Space" to "Poly" to check "is in or on Poly/Space", here is another good node. Edited October 3, 2021 by m.graf Quote Link to comment
the frog Posted October 4, 2021 Author Share Posted October 4, 2021 Hello Thank you for the answer. How evident and simple it is when you look at the solution.... and you know how to script nodes. My next step is to find a way to give name to objects directly from an excel file, or with a marionette script.. Quote Link to comment
m.graf Posted October 4, 2021 Share Posted October 4, 2021 (edited) Hello, I would try a database instead of "named objects"... greatings M. Graf Edited October 4, 2021 by m.graf Quote Link to comment
C.T Posted July 20, 2025 Share Posted July 20, 2025 (edited) Is there a simple way to make a automated schedule that marks the symbols ( codes V1, V2, V3, V4, W1, W2, W3, W4, W4, P1, P2, P3, P4 in this case is a floor, wall or Ceiling material finish) present per space? I use floorplan with codes (symbols) together with a worksheet schedule as an overview for the builder. (so he know what material to use in a certain space). The crosses I type by hand. Is there a way to automate this so the crossed are being placed in the cell as soon as I place a code into a particular space? Or any idea how to make this happen (some other approach/ tools) please? I've got Vectorworks Architect 2021 (and no knowledge of marionette) Edited July 20, 2025 by C.T Quote Link to comment
Silvano Mainardes Posted February 21 Share Posted February 21 The Space and Label object styles, as well as their report sheet, are perfect for this. Quote Link to comment
