Bruce Kieffer Posted October 2, 2021 Share Posted October 2, 2021 I have created a Vectorworks 2022 Cut List Template file and it is attached here. It includes instructions to use the worksheets. Check it out. Please let me know what you think. Cut List Template.vwx Quote Link to comment
Tobias Kern Posted November 6, 2022 Share Posted November 6, 2022 Hi Bruce, greetings. I solved a long time problem this week (with help of Pat). I often draw 3D symbols with 1 x 1 x 1 cm and scale these symbol-instances to my needed size. The problem was, that I can't get a working quantity take-off, because the symbols have different rotation in plan and formulas like height, width, … won't work. The solution is to get the scale factors into a worksheet formula. This can be done with: =OBJECTDATA('OBJECT VARIABLE', 102) | = x-scale-factor =OBJECTDATA('OBJECT VARIABLE', 103) | = y-scale-factor =OBJECTDATA('OBJECT VARIABLE', 104) | = z-scale-factor Now it is possible to get valid quantity take-off from every “simple” 3D geometry/symbols with worksheets. It doesn't matter how the symbols are inserted in plan the axis of the symbol counts, not the VW main axis. That's a huge improvement for me. Greetings from Germany. Tobi 3 Quote Link to comment
