Fairfax Posted July 15, 2004 Share Posted July 15, 2004 Hello, I am trying to use a staircase split with a landing and all is well, except that I cannot figure out how to adjust the position of the landing, i.e., the number of stairs before and after. Any thoughts? Thanks, Graham Quote Link to comment
CipesDesign Posted July 15, 2004 Share Posted July 15, 2004 Hi Graham, With your stairway selected, look in the OBJECT INFO PALETTE, right under the pulldown that allows you to select different configurations, is a field that says "LANDING TREAD". By changing the number you can adjust the landing tread. Hope that helps. Quote Link to comment
