Disappearing Walls
buz
I'm wanting to revise a drawing, adding/changing walls, but each time I draw a wall it vanishes from the page I'm drawing on. It shows as I draw it but once I click to end it, it vanishes.
Any ideas why this would happen?
Thank you
Buz
Most likely the walls you are drawing belong to a class that is set to invisible in your current sheet (or view). Try scrolling through your class pulldown making each invisible class active one at a time. I would guess that when one of those classes is active you'll have a whole bunch of 'invisible' walls suddenly appear.
Further, if you are using the 'wall type' wall tool, you can go into the select wall type dialog and change the walls' class assignment.
Peter Cipes
