D Wood Posted September 17, 2003 Share Posted September 17, 2003 I have a overhead garage door in a masonry wall - when I tried to widen it, I got this message A VectorScript error has occurred on this locked plug-in. Refer to the file "Error Output" for a further explanation. I clicked OK, then I got this message Object creation failed due to invalid parameter(s). Pleae use different parameter(s)! I searched for the Error Output file, which is not mentioned in Help, but even when I found it mean't nothing to me, and I can't paste it here. Both files are converted from VW8.5 and I have run Utilities upgrade to V2 objects. I am running VW10.5 on a 17" iMac with OS 10.2.6. How can I get this tool working again? Quote Link to comment
D Wood Posted September 17, 2003 Author Share Posted September 17, 2003 I should explain my reference to "both files" - I tried another job file and got the same result. I also have Julian Carr's WinDoor loaded, and I get the same message with that as well, so I am unable to modify existing or draw new windows and doors with either tool. Is it something to do with the plug-ins being locked? Quote Link to comment
ionw Posted September 18, 2003 Share Posted September 18, 2003 My guess is that you have a corrupted installation. I hgad this problem with my install, and I had only one program running at the time of install, when i reinstalled making sure there were no programs running the problem went away. Quote Link to comment
Guest Posted September 18, 2003 Share Posted September 18, 2003 You can also edit the workspace, remove the tool causing the problem and then add it back in again to see if that resolves the problem. If it doesn't, you may need to reinstall. Quote Link to comment
D Wood Posted September 18, 2003 Author Share Posted September 18, 2003 Thank you for your replies. How precisely do I edit the workspace, remove the tool causing the problem and then add it back in again And if I reinstall, should I reinstall just the VW10.5 download, or should I reinstall VW10.1.2, then the download? Quote Link to comment
Guest Posted September 22, 2003 Share Posted September 22, 2003 Reference the Appendix in the back of the VW User's guide for using the workspace editor. You'll delete the tool in the right column and then drag the tool from the left to the right to reset the tool. If you reinstall, and you installed using the 10.5 download, you'll have to reinstall 10.1.2 and then run the update again. I'm pretty sure the 10.5 update makes the changes to the 10.1.2 folder without copying the 10.1.2 folder and updating the copy. Quote Link to comment
D Wood Posted September 24, 2003 Author Share Posted September 24, 2003 In the end, I reinstalled VW10 from my CD, then (laboriously) upgraded step by step to VW10.5, checking each time that the tools were working. Everything seems fine again so far. Quote Link to comment
marksw Posted October 25, 2003 Share Posted October 25, 2003 I am now having a similar problem inserting door and french door symbos, not that I have upgraded to 10.5. Since this does not seem to be a singular problem to one indivdual....what gives? What is the best way to address this problem? Quote Link to comment
Guest Posted October 27, 2003 Share Posted October 27, 2003 Mark, What version of VW are you using? Quote Link to comment
D Wood Posted October 31, 2003 Author Share Posted October 31, 2003 I haven't had the problem of non working d&w tools repeat since I re-did the upgrade, so I guess the software just got into a tangle one time. The only problem I've had recently was when I opened a file to find that all the brick veneer walls I had drawn on a large house had mysteriously reverted to a 100mm (4") wall - fortunately I was able to recover a proper copy from my Retrospect back-up. So the lesson there is: back-up, back-up, backup! Quote Link to comment
