Chris T Posted August 21, 2003 Share Posted August 21, 2003 When I add a new floor to an existing file and then add the sheets. The class attributes which I customised changes to the default. Can this be fixed before the next upgrade to VWA. Thanks Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted August 21, 2003 Vectorworks, Inc Employee Share Posted August 21, 2003 I will add this to the bug list if it is not already. In the meantime, if you want to change class attributes of your standard classes, you can do so (persistently) using the Standard Naming command. HTH Quote Link to comment
