Poot Posted June 22, 2021 Share Posted June 22, 2021 (edited) Hi everyone, I am just making a simple site model and am experiencing a problems where the site model is cutting out a section for no apparent reason. I have tried adding extra point heights, 3d geometry but to no avail. There are not any site modifiers, or any other objects/layers to influence the site model. You can see the polygon and point heights I am using to make the site model below. Next you see the problem where the site model created from this data clips out a section for no apparent reason....and I cant seem to get it sorted. I have uploaded a copy of the file for testing....and maybe I am missing something obvious here? Help me Obi-Wan..... Test.vwx Edited June 22, 2021 by Poot Quote Link to comment
Vectorworks, Inc Employee Tony Kostreski Posted June 22, 2021 Vectorworks, Inc Employee Share Posted June 22, 2021 Hi @Poot, not sure why this would matter but the stake object on the bottom right (+4.55m) is ever so slightly outside the crop or boundary. As soon as I moved the stake to the nearest vertex point (0.0000005mm distance) of the crop the model appeared as it should. Hope this helps. 4 Quote Link to comment
Poot Posted June 22, 2021 Author Share Posted June 22, 2021 THANK YOU! I won't get the last 2 hours of my life back, but this will prevent me throwing my computer out the window. One of the joys of translating AutoCAD DWG's into VW I guess. Tried to be careful with the snapping, but obviously missed that. 2 Quote Link to comment
