hong Posted April 30, 2003 Share Posted April 30, 2003 Has anyone experienced this? Whenever I try to save a sheet, VW quits out mercylessly. I am on VW10.1. on Mac OX 10.2.5 Previously this file had few saved sheets that did not appear on the list when I click 'edit sheet' command. So I deleted these sheets from script palette assuming its malfuctioning and start anew. Since then, above problem persists. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 30, 2003 Vectorworks, Inc Employee Share Posted April 30, 2003 I haven't seen this. Do your sheet names have any unusual characters in them? Quote Link to comment
hong Posted April 30, 2003 Author Share Posted April 30, 2003 No, I don't think so. It is a siteplan with a survey file referenced. The survey file was originally DWG file and converted into mcd. Any thoughts? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 30, 2003 Vectorworks, Inc Employee Share Posted April 30, 2003 Set your document to active layer only and show all classes. Go through your document on a layer-by-layer basis and see if you have bad objects. (you may experience a quit.) If so, make a note of the layer with the bad stuff. Did you import ACAD layers to classes? Quote Link to comment
hong Posted April 30, 2003 Author Share Posted April 30, 2003 Tried as you mentioned. No quiting happened. Yes, Autocad layers were converted to classes. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 30, 2003 Vectorworks, Inc Employee Share Posted April 30, 2003 Well, this is an interesting puzzle. You might try sending in a file to Tech Support (or bugsubmit@nemetschek.net ) that exhibits this behavior. I'm sure they'd be interested to see it. Quote Link to comment
Guest Posted May 1, 2003 Share Posted May 1, 2003 You can try to break the workgroup reference and see if the crash happens. If it doesn't, then the WGP ref file is probably bad and will need to be copied to a new document. The script for the sheet may be an old script also. I've seen this happen alot since the convert to VW 9/10 occured. You may need to delete the sheet script and recreate it to get the sheet to work correctly. It may be something in the script itself that's buggy. We can't fix that stuff in Tech Support. If the script itself is buggy, then you'll need to send that to vs_Support@nemetschek.net [ 05-01-2003, 11:51 AM: Message edited by: Katie ] Quote Link to comment
