space tool
when creating a space object for a room and the room is an irregular shape, is there a way to move the text info so that it is centered in the room?
also i tried the "create spaces from walls" command. it didn't create spaces in all the places that i needed it so, i undid my action and a lot of the walls were partially gone/invisible. i tried quitting and not saving the changes. but when i opened back up, the walls were still missing. i had not done that much to the drawing this morning so, i just replaced it with yesterday's version.
cherie
vw architect 10.1/osX.2.4
The name/number/area/etc. tag has a control point on it, so you can move it wherever you like. If you move it off the Space object, it will stay connected to it using a little "leader line".
It's pretty hard from your description to duplicate the exact circumstances of your undo problem, but I'll have the engineer look into it. Thanks for the report.
