juanriverat Posted May 17, 2021 Share Posted May 17, 2021 Hi all, Is there a way of pre-setting the PDF export parameters? What i need is that the Resolution and the File Size reduction is always at 150 DPI. I want to avoid having to change those values everytime i need to export into PDF..... when i open different files. Thanks for the help. Quote Link to comment
drelARCH Posted May 17, 2021 Share Posted May 17, 2021 What about using 'Publish' command and using 'Save a set...' option...? Quote Link to comment
juanriverat Posted May 17, 2021 Author Share Posted May 17, 2021 I am exporting drawing that i have on the design layer... for that reason i can not publish. Quote Link to comment
drelARCH Posted May 17, 2021 Share Posted May 17, 2021 Ok. So you can then make a saved view from your design layer set up and use publish for saved view category... I dont know about any other way to store export settings when exporting directly from design layer. 1 Quote Link to comment
