dennisp Posted April 11, 2005 Share Posted April 11, 2005 All of a sudden my designs are not printing correctly. Only a portion of the design is printing. I went to Page - Set Area, it appears to be correct. Any place else to go to set print area, or to preview what will print? Quote Link to comment
Delmer Posted April 12, 2005 Share Posted April 12, 2005 The gray box that is your page size (assigned through Print Setup) shows exactly what will print, there is no preview necessary. If you have the correct printer & page size, along with an appropriate scale you should see on your screen exactly what will come out of the printer. The set print area (under the page menu) is used only if you want a drawing to be tiled over more than one page. On exceedingly large files your printer may run out of memoory. In HP prnters this is generally overcome by going into page setup/ properties/advanced tab/ select "In Computer". Quote Link to comment
Kevin Posted April 12, 2005 Share Posted April 12, 2005 Be sure that the "Print Current View Only" box is not checked. This is in the print dialog under Vectorworks. Quote Link to comment
