PRINTING PROBLEMS
dennisp
The gray box that is your page size (assigned through Print Setup) shows exactly what will print, there is no preview necessary. If you have the correct printer & page size, along with an appropriate scale you should see on your screen exactly what will come out of the printer.
The set print area (under the page menu) is used only if you want a drawing to be tiled over more than one page.
On exceedingly large files your printer may run out of memoory. In HP prnters this is generally overcome by going into page setup/ properties/advanced tab/ select "In Computer".
