Mat Caird Posted January 23, 2003 Share Posted January 23, 2003 So if I insert the drawing title object into a blank document, I can adjust the line thickness in the normal, using the attributes pallette. But, on some of my drawings, I cannot adjust the line thickness. Any ideas? win2k, VWA10. Technique; Select the drawing label object, change the line thickness in the attributes pallette. Result; in some drawings it changes, in others it does not. Quote Link to comment
Guest Posted January 23, 2003 Share Posted January 23, 2003 Are the PIO objects that "won't change" inserted in a wall such as the door or window PIOs ? Quote Link to comment
Mat Caird Posted January 23, 2003 Author Share Posted January 23, 2003 Thanks for replying Katie No the PIO objects that wont change are not inserted in anything. The PIo objects I have problems with include: drawing label & north arrow. If I copy them into a blank (default) drawing, the line thickness does change as required. Quote Link to comment
Guest Posted January 24, 2003 Share Posted January 24, 2003 Mat, Email one of the files demonstrating this problem to me at tech@nemetschek.net Put Katie in the subject line so I get it. I'll take a look at it and see what's going on. Quote Link to comment
