J Parkin Posted January 15, 2003 Share Posted January 15, 2003 Im trying to create a 3d model of a hilly site, with little success. Waht I have done is imported a Tiff of the contour map, traced the countour lines with polygons then used the "convert 2d polygons to 3d contours" function. up to this point is fine, I end up with a group of polygons layered above each other that look like a 3d model. However none of the sitework tools work, all say ' your drawing contains no DTM" What am I missing here? I think im doing it exactly as the manual states. thanks Jason Quote Link to comment
Robert Anderson Posted January 15, 2003 Share Posted January 15, 2003 OK, the 3D polys you've created are the site data. Now use the Site Model... command to create a Digital Terrain Model (DTM). This DTM, once created, can be displayed in various ways in 2D and 3D, and can be analyzed and modified to create grading plans, cut-and-fill, etc. Quote Link to comment
Guest Posted January 15, 2003 Share Posted January 15, 2003 Also, make sure you don't have process beds or update existing or create proposed checkmarked. If you have proposed or update existing checkmarked, you can get a related error since currnetly, you do not have a dtm in the drawing. Jason, if you want me to take a look at the file, you can go ahead and email it to me. I know last week was a strugle to get the DTM operational with the data. [ 01-15-2003, 09:40 AM: Message edited by: Katie ] Quote Link to comment
