fjgolf
Polygon extrudes
I have drawn my polygon and checked that it is closed, which it is but when I extrude it, it still won’t turn solid. Please help, I’m having a crisis. :)
@fjgolf check your attribute panel and class the polygon was drawn on, do they have a solid fill?
Also, extrudes viewed from TOP/Plan will show as unfilled unless turned into an AutoHybrid.
Two quick things to check:
  1. The polygon may be set to "Closed," but it still needs a fill to create a solid object.  Make sure the polygon as well as the extrude do not have their fill set to "None."
  2. Are you looking at the solid in wireframe view or something like OpenGL / Polygon Shaded / Renderworks?  In wireframe view, everything will appear as being not solid.
