DCI Posted February 3, 2021 Share Posted February 3, 2021 Please see two screenshots attached below... The first image is a screenshot taken from a design layer in OpenGL, when orbiting the lenses remain clean and exactly how I want them to render. The second is taken from a sheet layer of a viewport, rendered in OpenGL only this time I get random artifacts appearing on the lenses of this particular fixture. My first thought was that there may be some overlapping geometry (although this doesn't explain why it renders correctly when in the design layer) regardless, I tweaked the position of this polygon but no success. I also played around with crease angle, removing texture, setting solid colour, various lighting settings, turning off ambient occlusion and DPI settings of the sheet. Any suggestions on a fix would be greatly appreciated. Many thanks Dan Quote Link to comment
JBenghiat Posted February 4, 2021 Share Posted February 4, 2021 This looks to me like you have two objects that are coplanar. If there’s an object that’s supposed to represent the lens, nudge it away from the body by 1 pixel, or use push/pull to give it a depth of 1mm (away from the body). The sheet/design layer discrepancy could be due to a class that’s only visible in the sheet layer or just a difference in viewing angle. 1 Quote Link to comment
