hollister design Studio Posted February 3, 2021 Share Posted February 3, 2021 I noticed that when I export PDF I have a setting for 'grey level for greyed Layers and Classes" in the export options. I don't see that in the Publish as PDF options Where is this setting? Also fonts are coming out very heavy as if line weights are off. Example: Quote Link to comment
Pablo Prieto Posted February 9, 2021 Share Posted February 9, 2021 I think the setting you are searching is located on the lower right, next to the PDF. It shows as "options". You have to select first your Sheet layers then click options. After that you should be able to see all the settings available. I currently own the spanish version so apologize if it’s unclear, hope it helps! 😄 2 Quote Link to comment
hollister design Studio Posted February 9, 2021 Author Share Posted February 9, 2021 That's what I was looking for! Quote Link to comment
