jonp001 Posted December 16, 2020 Share Posted December 16, 2020 Hello all, I'm trying to change the class of a line from 'wall' to 'stair'. I can do this through object properties apparently, but my target 'stair' class doesn't show up in the object properties window. In fact, object properties 'classes' menu looks nothing like my navigation 'classes' menu. See attached screen shot. The question, then, how do I make the object classes menu look like the navigation classes menu so I can alter object classes on the fly? Hope that makes sense............ Quote Link to comment
zoomer Posted December 16, 2020 Share Posted December 16, 2020 You have to deactivate "Hierarchical Display". I think Navigation Palette has its own setting from the little Arrow, where you can deactivate "Hierachical Display" as it looks, you did - for Navigation Palette. But there is at least 1 other Setting somwhere - which is for other Palettes. Not sure if it can be found in VW Settings and/or Oragnisation Palette. 2 Quote Link to comment
jonp001 Posted December 17, 2020 Author Share Posted December 17, 2020 Thanks Zoomer, I've tried that one and and just get this - the hierarchical pull out is present on the tiny arrow on the navigation pallet but doesn't seem to be an option on the tiny arrow on the object palette. Confusing for a novice................... Quote Link to comment
zoomer Posted December 17, 2020 Share Posted December 17, 2020 (edited) Yes, this for Navigation Palette only. There is another Icon to switch in the Organization Palette > Classes Tab > bottom right. Hope this finally controls all Class Lists appearance anywhere else. (If Not there may be a third switch in VW Preferences ?) EDIT : ^ It is ! VW Preferences > Session > "Display Classes in popup menus hierachical" > OFF Edited December 17, 2020 by zoomer 1 Quote Link to comment
jonp001 Posted December 17, 2020 Author Share Posted December 17, 2020 Thanks Zoomer - not worked I'm afraid. I found the control in the orgnaization palette, but it did not effect the properties palette. I can't see anything in VW Preferences that would alter Class Hierarchical display. Thanks for your time even so Jon Quote Link to comment
zoomer Posted December 17, 2020 Share Posted December 17, 2020 22 minutes ago, zoomer said: VW Preferences > Session > "Display Classes in popup menus hierachical" > OFF 2 Quote Link to comment
jonp001 Posted December 18, 2020 Author Share Posted December 18, 2020 Brilliant! - thank you Zoomer and thank you for staying with me on this. Have a great weekend 🙂 2 Quote Link to comment
