Hi I'm wanting to add a long list of botanical plant names to the UserDictionary.txt Users\Ben\AppData\Roaming\Nemetschek\Vectorworks\2021\Plug-ins\Dictionaries
The first time I run the spelling I click "learn"(file VW generated) and it adds the word to the dictionary. I then manually open and add a new word (file VW Manually Added), but when running spell check again it doesn't see the word in the dictionary. I then click learn again and it overwrites everything into a new format (VW Learn Overwrite).
I've read in the docs that it should be the word followed by tab and then i, but this doesn't work either.
Please could someone attach their working manually generated file so that I can copy the format.
Thank you so much
Ben
UserDictionary_VW generated.txt UserDictionary_VW Learn Overwrite.txt UserDictionary_VW Manually Added.txt
