Create solid volume out of two 3D polys
Elin
Hi!
I want to create a solid volume out of a few 3D-polylines to calculate the volume from this.
The purpose is that we are drawing a pond and need to know how much water it can hold. We have already made a terrain and can get some numbers from the cut-and-fill calculations but it would be helpful to be able to draw the actual bowl too.
What would be our best option/tool to do this?
I can try to post the model or pictures if that helps further!!
Happy for some help!
Elin
Thinking about this differently will allow VW to calculate the required volume:
Draw/select the contour of the water surface as a 2d Poly
Convert to Site Modifer>Pad apply to the the Proposed Site Model and set its elevation to the water surface elevation
Run the Cut/Fill Update calculations in the OIP.
The water volume will be given as the fill volume.
