ryanww Posted August 17, 2020 Share Posted August 17, 2020 Hey - I'm pretty sure there is some issue with the logic on the jack panel wizard unless I'm just using it incorrectly. After creating a panel with 24 jacks (using repeat), I'm not able to make subsequent panels - the repeat number doesn't ever refresh.Video attached. If I can put in a request here - I'd way rather just have a custom named panel and # of ports over the drop down list of selected group/panel/port. And well to make it cleaner on the schematic, wish this would just have the title of the set of jacks and the jack numbers below in a little block or something. But I'd rather it work first 🙂 Screen Recording 2020-08-17 at 2.24.28 PM.mov Quote Link to comment
ryanww Posted August 17, 2020 Author Share Posted August 17, 2020 Actually I just realized that if the last set of them is highlighted, when re-opening the tool, it will not allow you to make a new set.. Kind of weird though. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 18, 2020 Vectorworks, Inc Employee Share Posted August 18, 2020 Hello @ryanww, When you have a selection of panels the tool works as an editing tool. You have to click on one of the selected panels and then you can renumber the selection using different settings. If you want to make new sequence, you will have to deselect all objects. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
