Christiaan Posted February 16, 2006 Share Posted February 16, 2006 I've imported a file into VW 12 and all the 2D door swings have disappeared. Had a look through the door PIO but couldn't see anything obvious. Any ideas? Quote Link to comment
Guest Posted February 16, 2006 Share Posted February 16, 2006 Check to see if you have any invisible classes, mainly a style class. Quote Link to comment
Christiaan Posted February 17, 2006 Author Share Posted February 17, 2006 That's what I thought, but I had all the style classes on, but then I didn't check the other classes, which was indeed the problem. Thanks. Thing is I can't work out which class it is. I checked the class styles settings in VW 11 and they're all set to None. So any idea how I can work out what the class is (without going through a process of elimination)? Quote Link to comment
Christiaan Posted February 17, 2006 Author Share Posted February 17, 2006 Okay, I worked it out, it was on some random class called Sills (which I'm not sure where it came from because I've been away from work for a couple of months). To work it out I converted the door to a group and then dug down into it to select the leaf. Quote Link to comment
Christiaan Posted February 17, 2006 Author Share Posted February 17, 2006 It seems the VW 12 import process, for whatever reason, creates this class and adds my door swings and leaves to it. Quote Link to comment
Christiaan Posted February 17, 2006 Author Share Posted February 17, 2006 Question is, should I keep this class for any reason and leave the leaves and swings on it? Quote Link to comment
