max123456 0 Posted June 24, 2020 Hello I am trying to import connections to an MySQL/ODBC database The export of the connection works fine. But when i try to import the just exported file again i get the following error message: Unable to access database. ODBC Log: [1064] Driver error: 37000 [MySQL][ODBC 8.0(w) Driver][mysqld-8.0.20]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '[000_u_fixture_configuration]' at line 1 Thanks in advance Max VWX 2020 SP3.1 Build 537701 (64bit) DBConnections.xml Quote Share this post Link to post
