Onink
Text height/size
With which node can I adjust the text height/size of a text?
I want to be able to change the text height in in the pio
That works perfect, thanks.
But now the font changes to the first font in the list, @batang
If I use a string or a name node at the IDfont port it doesn't change this.
How do I set this to Arial?
Hello,
You need to use the node "Get Font ID" between the String node and the iFontID port of the Set Char Properties node. When in doubt, check that the prefixes of the output and input ports match. (They won't always match because of generic prefixes like "item" and "list", but they can be helpful in these situations.)
Yep, that does the trick.
Thanks a lot for your help.
