Paolo
Angle of an image
Hello all,
is there a way to get the rotation angle of an image (bitmap) inserted in Vectorworks?
The angle is clearly shown in the OIP but it seems to be unreachable by code 🤔
Here's what I tried:
vs.HAngle(h)
This returns always 0.
I also searched in the appendix for some documented index to get the angle, but found nothing…
vs.GetObjectVariableReal(h, index)
Also tried to get it from record fields…
vs.GetParametricRecord(h)
but Bitmaps are a native type and not plugin objects, so neither this worked…
Other ideas / suggestions?
vs.GetEntityMatrix() should do it. The z rotation should give you the plan rotation.
Thank you JBenghiat, just tested and it works!
r, offset, rotationXAngle, rotationYAngle, rotationZAngle = vs.GetEntityMatrix(imageHandle)
rotationZAngle is the image (imageHandle) rotation value (the same showed in the OIP)
