I have two problems concerning the Spotlight Numbering command.
We have a Template File in our company. This File is continuously updated during the years. Some months ago I added some Fields in the LD Parameter dialog. I then removed them because we don't need them anymore.
First
Spotlight Numbering Field List entries differ from Lighting Device Parameters. In the Field List I can still see the removed LD Parameters (E_Einspeisung, E_Havarie, E_...). Reloading the default Parameters, Restarting etc. didn't help.
How can I get rid of them?
Second
As it is said in the VW Help:
"The Spotlight Numbering command provides a method of numbering instruments or other light plot objects such as focus points, hoists, cable runs, or any drawing object with an attached record"
I don't know if I understood right, it should be possible to use the command also for Symbols with an attached record. Because a symbol is drawing object and has a record attached.
I have two Symbols in the Drawing with attached records and texts linked to this record. I want to number them with the Numbering Tool.
Wether selecting the symbols and running the Spotlight Numbering command, neither deselecting the Symbols and running the command works for me. It seems that they are not registered by the plugin.
Rob87
Hi Everyone,
First
Second
What did I miss?
Thanks!
Test File Spotlight Numbering 200303.vwx
2 answers to this question
