e.g. section style of grey fill and thick lines - when used on section viewport this is not seen - just think lines and white fill....or in plan when in the drafting view - class characteristics not visible, although the attributes palette shows them correctly.
I've had this slightly resolved in that the 'plan' characteristics apparently only appear if you render the plan as OpenGL - this seems very odd, to have to render all plans just to have the existing walls in grey with a thick line weight....but then if you want the wall to have a texture in 3D you can't have just grey in plan???
HWood
Edited by HWoodevolved knowledge
1 answer to this question
