Mickey Posted September 6, 2005 Share Posted September 6, 2005 I posted this in the printing section but there's been no response so I'm trying here. http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=22;t=000527 we just installed a new HPGL2 card with a differnt driver in hopes this would alleviate the problem WRONG. The problem still exists. I can print no problem with all layers turned on, but if even one layer is greyed out then it won't print correctly. With the new driver information is making it to the plotter but not all of the layers. This is definately something with how VW interacts with the print driver. Printing to a HP455ca has no problems at all. Quote Link to comment
islandmon Posted September 6, 2005 Share Posted September 6, 2005 Have you tried printing to PDF. Are you printing from Viewport? The HPGL2 is a postscript emulator. If you're on OSX hen you can by pass the HP drivers and use the GIMP Drivers via Printer Utility , instead. Quote Link to comment
Mickey Posted September 6, 2005 Author Share Posted September 6, 2005 Windows 2k No viewports. PDF's print just fine, but I don't want to go through the making pddf's process and print form Acrobat I want to print directly from VW. I can print full color no problem. Quote Link to comment
Lucid Phil Posted October 11, 2005 Share Posted October 11, 2005 I can't print any greyed layer or class on my HP120NR UNLESS.... I rasterise the document in the print setup. Then all is well. It just takes a little longer to process but it saves all that wasted paper. Quote Link to comment
Kevin Posted October 11, 2005 Share Posted October 11, 2005 quote: Originally posted by mickey: ...Printing to a HP455ca has no problems at all. I am curious why you are using a 500 when the 455 works fine. I have a 455, but on a Mac. Quote Link to comment
Joe Golden ENT Posted October 15, 2005 Share Posted October 15, 2005 I am having problems printing to the 500 as well. My viewport extended over the title block, and what ever it was over didn't print including everything in the viewport. We are using the driver without the HPGL2 card. I tried restarting the printer and the cpu, but nothing. Having similar problems like you in your other post. Only able to print from PDF. Quote Link to comment
