James Pitt Posted June 2, 2005 Share Posted June 2, 2005 I would like to be able to create a section through a model. is this possible using a viewport? i have created my veiwport and added a crop to it. is it possible to now add a depth/extrusion to the rectangle that defines the cropped viewport? so that i can define in the "Z" direction what is veiwed. Quote Link to comment
islandmon Posted June 2, 2005 Share Posted June 2, 2005 Perhaps, you need to create a 'cut 3d section' on a new layer then Viewport that layer. The polygon crop works regardless of the plan or perspective or orthogonal projection. But you cannot have multiple crops or nested & embedded crops. Make 3d sections then viewport & crop them as required...there's no end to the possibilities. Quote Link to comment
