Macluskie 1 Posted August 8 I have Prolyte Box corners in my the stock, a 289mm cube which conical couples can be attached to form anything from simple L corner to 6 way.https://www.prolyte.com/en/products/aluminium-truss/box-corners/box-30v-0-boxcorner-30v The Conical Couplers measure 75mm and so when assembled in a L corner for example measures 364mm x 364mm The Vectorworks Prolyte Library has the "naked" H30V box I've tried fiddling about in the "customise" settings in the OIP to create a simple L corner with the correct dimensions but cant seem to get it to work at all What am I missing? Thanks Quote Share this post Link to post
Macluskie 1 Posted August 8 Doesn't seem to matter what size I put in the Custom Box the Box Corner and associated snap points remain the same i.e. the Naked Cube The red box is the size the corner should be Quote Share this post Link to post
Macluskie 1 Posted August 8 Found a solution using this symbol ...DOH Still don't understand what the "customise" Truss Properties OIP fucntion does though so any pointers on that most welcome :-) Quote Share this post Link to post
skn 0 Posted August 8 Did you hit the update/refresh button after you changed the settings? Quote Share this post Link to post
JustinVH 42 Posted August 8 (edited) @Macluskie Feel free to DM me and I will walk you through what all of those settings mean. I am one of the developers that setup all of the truss that is included in the libraries and would be glad to give some assistance. I have also attached a screenshot of the L1, L2, and L3 settings of the original H30V box corner. If you add 75mm to the symbol for the spacers also be sure to shift the entire symbol to the right by 75mm in the 3D and 2D symbol components. The insertion point of any straight truss and corner must be left center so that the auto connect engine can use the measurements in the customize window to calculate the proper connection points. Once you are finished with your changes be sure to click the apply customization button to save your settings. If you have any questions please let me know. Edited August 8 by JustinVH Added screenshot 1 Quote Share this post Link to post
Mike Wright 30 Posted August 20 You are correct that you need to use the ATT symbols, they come in various length but be aware that the stock symbols often have incorrect/incomplete truss records. I have modified mine for S52, 40V and 30V ATT along with building my own symbols for CCS6 female couplers in set's of 4. Frustrating but has proved worthwhile as no-one seems to want simple truss structures! Quote Share this post Link to post
