  • 3
Dual Dimensions Not Working in One Drawing.
Bruce Kieffer
Has anyone else had this problem? I created a dual stacked dimension standard in my drawing, then I noticed that the "inches" figure was not correct. It was not showing the fractions. The width of the box is 23-5/8". The dimension shows 23". I checked all of my settings, units too, and they are all correct. If I change the dimension to another standard, then the dimension shows the fractions correctly. This is what I see:
1070733471_ScreenShot2019-07-20at4_31_54PM.thumb.png.7c5cbee651a715a05e418eb7d97d3559.png
To troubleshoot I opened a blank drawing and created the dual stacked dimension standard there and it works. Then I copied the layer objects from the offending drawing to the blank drawing, and it works there. This is what it looks like in the blank file:
1229166659_ScreenShot2019-07-20at4_31_41PM.thumb.png.600cccf74b16a2af12398bf76f9a64a1.png
Any suggestions what the problem might be?
Strangely, dual side-by-side shows the dimension correctly:
1087809125_ScreenShot2019-07-20at4_49_34PM.thumb.png.8781a4103424b4d42fe200c8457247d4.png
OK, I think I narrowed the problem down to that the fraction does not show if the inches fraction is set to a stacked fraction. I tested that in both drawings and found this is true.
1187088397_ScreenShot2019-07-20at4_55_48PM.thumb.png.7002d98f9f8f4b6d48acf9c23ad7ca7c.png
I also tested ungrouping the dimension and that makes the fraction visible.
I guess this is another bug 😫
Edited by Bruce Kieffer
4 answers to this question
Guest Alex Sagatov
@Bruce Kieffer This a confirmed bug that I actually previously submitted ( VB-154481 ). I stumbled across this a few months back as well and came to the same conclusions. Once I get a further update, I'll let you know.
I am also moving this into the "known issues" section.
