Moving Walls
When I was using VW10, I used to be able to move a wall without it being disconnected from the others it is joined with. Is this a feature only in VW architect? I'm using VW11 without Architect now, and can't seem to find the toggle to lock the wall joints. thanks.
sorry I should have read more carefully, this is an Architect only feature..
There is another way, and that is to select all the walls that you want to change.
Select the 2D Reshape tool.
Drag a marque around the walls that you want to move.
Then drag a wall, or use the move command to stretch the walls.
If you have my Essential Manual this is covered on page 82...
manual available from:
https://vesta.safe-order.net/archoncad/manuals/manuals.php
