Hugo Posted April 20, 2005 Share Posted April 20, 2005 Hello. I have a very big problem. I'm unable to print from VW 11.5 under Mac OS X 10.3 (10.3.8 and 10.3.9) to an Epson Stylus 1280 printer connected via USB. This happens in both a Powermac G4 400 mhz and an iBook G4. All other apps print successfully (Word, Preview, Firefox). Also tried with an Stylus 740 and same problem. Tried reinstalling printer, then VW and then the entire OS. No success. VW still doesn't want to print! Tries to create a printer but no success. HELP please! [ 04-20-2005, 10:37 AM: Message edited by: Hugo ] Quote Link to comment
Hugo Posted April 20, 2005 Author Share Posted April 20, 2005 I have discovered THIS solution in another post. IT WORKS! Dtheory posts: Hello All, I have noticed a curious phenomenon. I too had the problem refered to by Christiaan (above) >>3) all printers are missing from the VW print dialogue box so we can't print For some reason moving my Vectorworks folder out of the (default) "Applications" folder to another that I have created on my machine called "Applications (X)" brought the printers back... moved the folder back to "Applications", the printers disapeared again. Printers seem to be gone unless my vectorworks folder is in any folder OTHER than the default applications folder... (yes I have repaired permissions for my machine) Printers also are present when logged in as root though my normal day to day account is administrator... [ 04-20-2005, 11:30 AM: Message edited by: Hugo ] Quote Link to comment
islandmon Posted April 21, 2005 Share Posted April 21, 2005 Get yee the fab utility 'Cocktail' from versiontracker.com/macosx and then 'Re-Bind' and re initialize the OSX Finder database. You will be amazed at the results. Set the Cron Scripts to run weekly. And empty all that trash... clean out those caches ... and .ds_store files , too. Quote Link to comment
