halfcouple
some rookie questions on marionette , creating a plug in object from symbol
I want to create a marionette object out of an existing symbol. For example the symbol should get an x-parameter that moves the symbol in x-axis by this value or is mirrored along two parameter points. How do I tell the network which symbol should be handled ?  Do I have to put the symbol into the wrapper or do I have to put the wrapper into the symbol definition? Or do I have to convert the symbol to a group and handle this group with a special node ?  How do I create such a plug in object ?
All example networks I found do the drawing from scratch, which is "draw a line or rectangle and do with it whatever the nodes say". But what I want is: "Take this symbol or group and do what the nodes say".
I was successful with creating marinoette menu commands which use the [Objs by Crit] - node and does what I want with the object that matches the criteria. But I want to have Objects with marionette parameters in a library that can inserted to my file. ( = Object nodes with "pre-defined drawing" ? )
I fear I'm completely tapping in the dark, and maybe completely misundestand the use of Marionette.... Maybe someone can show me a simple example file with a symbol or group that is somehow controlled by marionette ?
Hi halfcouple
Thats not so Complex:
1.
1468972313_Bildschirmfoto2019-04-04um13_13_54.thumb.png.8b3ddbc6ae761e147c8f4ce34c991be2.png
2. Right-Click on a Node -> Wrap to Marionette Network* -> Right-Click to the Wrap-Node -> Convert to Object Node*
2129763521_Bildschirmfoto2019-04-04um13_12_59.thumb.png.dffd56317c08278c77cae34f22606b54.png
(If you give the nodes a name, they will appear in the OIP (e.g. "X_Axis"))
*Or a similar command name (have only the German VW version).
Greetings KroVex
Ooooooh, seems to be that simple:
Symbol and nodes within the wrapper, wrapper converted to object node .... that's it !
Something has blocked my brains !
Thanks much !
