Exporting Worksheets & DWG
Hi,
I would appreciate some help. Do worksheets export into a DWG file or are they attachments? I mean, specifically, when the acad user opens the file, does he or she see the sheets in the file? If not, is it possible to embed the worksheet as text into the VW 11 file?
Thanks for the information, if only everybody used VW.....
asm
A Worksheet is not exported as a graphic object. The best thing I know to do is export the spread sheet & have the person importing the DWG/DXF file to open an Excel document & import the exported Worksheet into EXCEL. The worksheet is still usable if this is done.
If you want the information from the worksheet to appear on a drawing, you can export the worksheet as text, then open the exported text file, copy the data, and paste the Block of text onto your drawing.
I suppose one could also copy & paste the information from each ?cell?; if there is not too much information.
