Hi there
I have a title block and in this title block  I have a field, that tells which revision the drawing is in (see picture below)1.thumb.JPG.9e822c94897ba75d76e5cfb51bbdce70.JPG
But when I create the revision and select "apply Revision Data to : All Active sheets"  Theres is a problem
The revision line on top of the title block is correct on all sheets, but the field in the title block is not correct.
on the sheets where i stand, when i creating the revision is correct with "A" (see picture above" but in the remains sheets the field say "none" (see picture below.
Hello Mike,
This is fixed in VW2019. As for VW2018, you have to open either the Title Block Manager or the TBB Settings dialog, in order to update the Current Revision Number value.
Best Regards,
Nikolay Zhelyazkov
