Mikedk64
105 -
Reputation
2 NeutralPersonal Information
Location
Czech Republic
Recent Profile Visitors
@Nikolay Zhelyazkov That worked :) Tanks! :)
Hi, I have made a worksheet that allows me to see what revision the different sheets are in. But when I get these squares in the end of the data. Is it possible to not have these in my worksheet?
Hi, Is it possible to add a parameter in the navigation vindue (see picture below)
I did see that my drawing was far away from my user origin, so that why everything disappear.
Hi, I am trying the new autoturn feature in Vw2019, but have some problems with it. When I open a drawing (created in Vw2018) and send to autoturn online it appear fine in the window. But when i then zoom or pan the window the drawing disappear. Why do this happened?
Hi, I have a template file on my computer, that i want to import to an "old" drawing. So I get all the classes, viewport etc from the template file to the drawing. Is this possible in one move?
Ohh okay. I am still working in VW 2018, so maybe i should try and upgrade to 2019 :)
Hi there I have a title block and in this title block I have a field, that tells which revision the drawing is in (see picture below) But when I create the revision and select "apply Revision Data to : All Active sheets" Theres is a problem The revision line on top of the title block is correct on all sheets, but the field in the title block is not correct. on the sheets where i stand, when i creating the revision is correct with "A" (see picture above" but in the remains sheets the field say "none" (see picture below.
Hi, Are there a way to change all title blocks in my project in the same time? We have two different title blocks, and it would be great to change all the title blocks in one move :)
I have now tried the "save as" in VW and it is the same result
- 5 replies
- title block
- data stamp
(and 1 more)
Tagged with:
usually we rename the file outside VW (in the folder) Other times we may copy and paste the file outside VW
- 5 replies
- title block
- data stamp
(and 1 more)
Tagged with:
Hi, I have created my own custom title block. It has a field where the file name is, this field contains a file stamp that gets its information from the actual file name. When I insert this title block on a new drawing in my project, the file name field is correct filled. But if i change the file name and open the file do the old file name still appear in the "file name" field. The other day i discovered that if I mark a title block and then uncheck the "This title block is active" box and the check it again, the file name stamp is updating on all drawings. BUT is it possible to force this field to automatic update the file name, if there has been a file name update? I work in a quite big department, and I am afraid that not everyone remember to do the "uncheck and check" thing.
- 5 replies
- title block
- data stamp
(and 1 more)
Tagged with:
Hi, Is it possible to have the adjust flipped text automatic turned off in my viewport on my template?
Hi you all, My workplace are looking into Vectorworks, and i am the man to setup our new template. I was told, that they want to draw in 1:1 scale, so the design layers are in 1:1. Our sheet layers (viewports) is typical in 1:100 and 1:200. Everything is good, excpet of one "hopfully" small thing. We have different line types in our drawings (water, electric, gas etc.) and these have different line styles and colors. I have made different classes to these lines, so it is easy to switch around them and to edit the style. Now the problem: When i draw a line in my design layer (scale 1:1) can i see the color of the line, but the style is "gone". Well it is not gone, but I have to zoom alot in to see it. When I then switch to my sheet layer (scale 1:100) is the line just fine, with the color and style. Is there a way (a check mark, option, etc) to do so the line is looking correct both in my design layer and sheet layer? Alternativ must we draw in scale 1:100.
@markdd that is cool. It is exactly what i was looking for! :) Now i just need to figure out how I make a good realistic render style.
