Marzii
Renderworks blank
Hello,
I just tried rendering something with Renderworks but it was all blank. I have seen that a couple of people had this problem before but there was no real solution posted. What steps can I do to solve the problem?
On the picture you can (or can not) see a wall with an opening.
Greetings
Marcel
There is a known bug in some versions of VWX where the render in a design layer will fail. Try creating a sheet layer VP and render there.
Same problem on the sheet layer
EDIT: Also tried different projects. Same issue. So it is not project-related.
Edited by Marzii
That's a bummer but it's true.. I might send it to another student to see whether the file or my vectorworks installation is broken.
Does the same render issue occur after a full restart of your machine?
What is your image compression setting? Try changing it from Preferences>Edit>Default compression to PNG. We have a known bug about JPEGs in SP2.
