Michael Gilbert Posted November 15, 2018 Share Posted November 15, 2018 I have been trying to set up a macro that will click specified button on Obj Info palette depending on trigger, e.g. Command+3 (on numeric keypad) clicks bottom right button. This used to be easy as the button display was static. Now it expands and contracts based on an objects dimensions. However, I can work round this but need to ascertain how may steps in button expansion there is and x/y dimension ratio that triggers expansion. For a horizontal rectangle (macro only works with rectangles) where dims x > y it appears that once x/y is ≥ 1.11 then button array expands. Also, I can only detect a single expansion. For a vertical rectangle where x > y it appears that once y/x is ≥ 1.12 then button array expands. Also, I can only detect a single expansion. No steps due to in x/y ratio. Can anyone confirm that there is only a single expansion of the button array? And someone from tech support confirm these ratios as the triggers for button array expansion? Apologies if posting in wrong forum. Using VW 2017 on Macbook Pro OS X 10.11 Thanks Michael Quote Link to comment
