ericjhberg Posted August 30, 2018 Share Posted August 30, 2018 I've got over 60 different SketchUp models I need to import and due to resource conflicts, I have learned that it is best to import them all into one file, all at once. That said, the SketchUp import only processes one file at a time, needing the user to accept each import manually. It's at the pace of about one import every 2 minutes or so. I was wondering if there was a way to script this import process so that Vectorworks would just use and import the same settings for all the files, without the need to have a user accept each import every 2 minutes for 2 hours of time? Any help or suggestions are welcome, thanks. Quote Link to comment
Andy Broomell Posted August 31, 2018 Share Posted August 31, 2018 I would utilize this too. Should be a built-in function just you can currently import multiple DWGs. Quote Link to comment
