Bruce Kieffer Posted May 26, 2018 Share Posted May 26, 2018 Is there a setting to make the center point tick mark larger and bolder? I can hardly see it. Lots of squinting! It shows up better in my screenshot than in Vectorworks. Quote Link to comment
Gadzooks Posted May 28, 2018 Share Posted May 28, 2018 Hi @Bruce Kieffer Do you mean the internal origin? Or - sometimes when I want to keep something in sight, I place a cross or bullseye on the drawing. So it doesn't get caught up with the other drawing elements, you can either place it on an underlayer (just for this exercise) or choose Modify -> Lock to protect it on the same layer as everything else. Hope this helps Quote Link to comment
Bruce Kieffer Posted May 28, 2018 Author Share Posted May 28, 2018 @GadzooksThat is not what I need, but it is something I knew nothing about, so I learned something new. I need the center point tick mark of an object to be easier to see. This may be a wish list item. Quote Link to comment
Gadzooks Posted May 28, 2018 Share Posted May 28, 2018 50 minutes ago, Bruce Kieffer said: That is not what I need Oh, ok Bruce - I took a bit of a flyer there as I couldn't make out any other parts in your image that pointed to it being object centre-point you were after. You're right, there are sections of VW operation that would be helped by larger screen 'markers'. It doesn't help that the centre mark is a 'relative' hint and will reduce as you try to zoom it. Best way I can think of would be to use snapping to best advantage (even to adjust the size of the acquisition/snapping boxes in VW preferences) to better highlight the parts you need - which I assume you're already doing. Quote Link to comment
Bruce Kieffer Posted May 28, 2018 Author Share Posted May 28, 2018 3 minutes ago, Gadzooks said: Oh, ok Bruce - I took a bit of a flyer there as I couldn't make out any other parts in your image that pointed to it being object centre-point you were after. You're right, there are sections of VW operation that would be helped by larger screen 'markers'. It doesn't help that the centre mark is a 'relative' hint and will reduce as you try to zoom it. Best way I can think of would be to use snapping to best advantage (even to adjust the size of the acquisition/snapping boxes in VW preferences) to better highlight the parts you need - which I assume you're already doing. Yes, I am doing that already. I will add this to the wish list. Quote Link to comment
