Mikedk64 Posted April 17, 2018 Share Posted April 17, 2018 Hi, My title block is acting wierd. In some of my fields I have a drop down list to choose from. ex. Scala. So when I have to set the scale in the title block, I have some pre defined scales to choose from. Bit the drop down menu is acting wierd. Let me try to explain my steps: 1: I open my title block style, and creating the drop down menu with some values 2: I import the title block style to a drawing and select the wanted scale. But here the drop down is empty. This is the same case if, it actually works, and I afterwerds update the style. then the new values dont appear on the drop down Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 17, 2018 Vectorworks, Inc Employee Share Posted April 17, 2018 Hello Mike, I am not able to reproduce this issue. Could you send me the test file, so I could see what is wrong there? Thanks, Nikolay Zhelyazkov Quote Link to comment
Mikedk64 Posted April 17, 2018 Author Share Posted April 17, 2018 Ok, I see if i import the sheet border with the sheet border button It is correct. Before did i just go to the ressorce manager and draged it to the drawing. That is maybe not the best way to import the border Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 17, 2018 Vectorworks, Inc Employee Share Posted April 17, 2018 It should be working fine with Drag&Drop too. Did you see the Resource Name Conflict dialog? If so, what option did you choose? Quote Link to comment
Mikedk64 Posted April 17, 2018 Author Share Posted April 17, 2018 If I start a brand new drawing and dragging the sheet border from resource the drop down is blank. And if i use the sheet border button, it is importing just fine. The sheet border is in a file under favorit in my resource manager Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 17, 2018 Vectorworks, Inc Employee Share Posted April 17, 2018 Could you send me the file that is in your favourites folder? I have tested again with Drag&Drop and file from favourites, but still cannot reproduce the issue. Quote Link to comment
Mikedk64 Posted April 17, 2018 Author Share Posted April 17, 2018 Here you go TEST_MIKE.vwx Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 17, 2018 Vectorworks, Inc Employee Share Posted April 17, 2018 Thanks, I managed to reproduce the problem with your file. Will try to find out why this is happening. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 25, 2018 Vectorworks, Inc Employee Share Posted April 25, 2018 Hello Mike, The problem here is that editing pulldown fields is not updating the choices for the title blocks. This is going to be fixed for Vectorworks 2019, as the fix is not trivial. Best Regards, Nikolay Zhelyazkov Quote Link to comment
