I have been using the "Drilled Footing" tool to place piles on a project I am working on at the moment.
The project requires straight piles (no bell end to them) so I have been setting the "Bell width" and "Bell height" to 0.
All displays correctly but when I checked the length and toe level they are not correct.
Example of 600mm pile with a toe level of -5000.
1. Create a new file
2. Select: Building Shell> Drilled Footing
3. Enter the following:
x = 0
y = 0
z = 0
Rotation = 0
Diameter = 600
Bell width = 0
Bell height = 0
Top datum = 0
Bearing datum = -5000
Now check the top and bottom levels of the pile (drilled footing):
Top level = 0
Bottom level = -5300
Measured length = 5300
The length should be 5000 but it has increased by 300
However if I set:
Bell width = 600 (same diameter as the rest of the pile (drilled footing))
and
Bell height = 0
the pile is now drawn and measures correctly.
Is this the only way to draw a pile without the bell end; should entering a bell height and width of 0 give the correct length?
It would useful if the ("z" /Top Datum) could be tied into the stories.
axhake
x = 0
y = 0
z = 0
Rotation = 0
Diameter = 600
Bell width = 0
Bell height = 0
Top datum = 0
Top level = 0
However if I set:
and
Bell height = 0
0 answers to this question
