Hugo Posted June 15, 2004 Share Posted June 15, 2004 Please help me! I'm using VWA 10.5.1 and I'm placing windows from the objects palette. I have inserted several windows that suit perfectly to what I need except they insist on having a transom, that I can't remove because the check box it's grayed out and can't be changed. I'm working on a window in a wall with a segment or ellipse as top shape. If I insert the window as a cased opening it has the shape I want, but when modifying it to biparting casement (as I need) or to any other configuration, it automatically gets a transom which I can't remove. That is the simple thing I need... REMOVING the transom. Any ideas??? Katie??? Thank you. Quote Link to comment
CipesDesign Posted June 15, 2004 Share Posted June 15, 2004 Hugo, I had a similar problem lately (with doors & transoms). It turns out that for some reason if I selected "transom" when I FIRST used the Plugin, the transom would be "locked" in (and grayed as you say). In a new file, I tried the same thing and DID NOT select "transom" right off the bat. Everything then worked as expected. Peter Cipes Quote Link to comment
Guest Posted June 15, 2004 Share Posted June 15, 2004 It was a bug in an earlier version of VW, but was fixed by VW 10.1.2 or 10.5 - I can't remember which one. Go to About VW either in the VW pull down in the upper left corner of vw (mac) or the Help menu (PC) to verify the exact version. Quote Link to comment
Guest Posted June 16, 2004 Share Posted June 16, 2004 Can you email the file to me, please? Quote Link to comment
Hugo Posted June 17, 2004 Author Share Posted June 17, 2004 Katie, I'm running 10.5.1 Quote Link to comment
Hugo Posted June 18, 2004 Author Share Posted June 18, 2004 Katie, I will email it to you right now! Thank you. Quote Link to comment
