MRD Mark Ridgewell 48 Posted October 13, 2017 Really like the new title block manager . One comment, the North arrow, not the easiest to position nicely on the sheet...be easier if you could re-position it in annotation like you would with viewport annotation? Quote Share this post Link to post
bcd 292 Posted October 13, 2017 Yes, I think the TBM was an important addition and step towards co-ordinate the drawing (s). The MN declination on/off switch was broken in my test. The N-arrow comes with a blue handle to re-position it graphically. Also hold ~ to temporarily disable snaps. Quote Share this post Link to post
MRD Mark Ridgewell 48 Posted October 13, 2017 Great, found the blue handle, thanks! I see it works for the drawing stamp too - a nice touch - a real time saver! Being picky now,; issue sheet (and generally) as a UK user, date display is usually, dd/mm/ yy rather than mm/dd/yy.....I wonder if there's a setting somewhere to swap this over, had a look but can't see it... Quote Share this post Link to post
MRD Mark Ridgewell 48 Posted October 13, 2017 Even more picky now.... The issue sheet format is rather unusual in how it presents issue data as it creates a column for each revision. So, if I issue 4 drawings of different revisionson the same date, I get 4 new columns so over a project, the issue data table will potentially get quite big.. I wonder, is there a way of getting something along the lines of... Quote Share this post Link to post
