Asemblance
Undo History Grouped Bug
Hi,
I have my undo history set to 'Grouping All View Changes', which works well for the most part. However, in certain files this setting appears not to work properly..
if I navigate using shift+mouse scroll wheel (horizontal) or alt+mouse scroll wheel (vertical), it does not group these changes. What this essentially means is that I can't use this method of navigation without making my undo history useless!
Again - this only seems to happen in certain files. Any idea what could be causing this? Perhaps I have some other setting enabled in the file which is overriding the group changes selection?
Thanks!
2 answers to this question
Confirmed as an existing bug, adding this thread to the case. This behavior is not intended, we apparently have also seen it with certain kinds of trackpad input as well. VB-129992
